240Z PCV?
Guest kcambron
Guest kcambron
I just bought a 240 and smell exhaust fumes, the
rocker cover has a small breather on the top of it,will hooking the hose back up to this help, if so where does it route to?
Thanks for the replys!
The exhaust fume issue is very common among early Z owners. Using the search function will unveil a wealth of info on the subject. But, to start you off, i'll add alittle info here.
The exhaust fumes mainly come from the rear of the car due to a combo of aerodynamics and bad sealing in the rear of the cars. Most people improve/correct the problem by adding any combination of the following until tolerable: tailight gaskets, rear hatch main gasket, seals around gas filler and/or sealing up the various rubber grommeted openings in the rear of the Z.
The search will go into much greater detail for you. Good Luck!
Jason
