TomoHawk Posted August 26, 2002 Share Posted August 26, 2002 My turn signal lever on the '78 280Z is funny the way you need to move it up or down to get it to turn on. You also have to pull it back slightly, otherwise it won't engage, and turns off when you let go. Does this mean it is worn down and must be replaced? Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 26, 2002 Share Posted August 26, 2002 You might try taking it apart and cleaning up the contacts.  Pete Paraska has some info on his site concerning the poor design of the turn signal set up on the 240's  http://mywebpages.comcast.net/pparaska/turnsgn1.htm  I assume it is a similar problem on the later models. Anyway the link diagrams how to add headlight relays to reduce the current flow through the switch. If your current switch is corroded and/or dirty then you will still need to overhaul it to make it work with the relays. Quote Link to comment Share on other sites More sharing options...
