aftermarket a/c pulley available
1 tuff z
i have an aftermarket a/c single v-groove pulley available. if you cover shipping and what i paid to have it blasted and plated [$5] it's yours. it was made to fit inside of the inner diameter of the stock crank pulley and comes with a longer bolt, which goes through it and the crank pulley to attach it. it also has 2 allen head screws that go though it into factory tapped holds outboard of the center hole to keep it spinning at the same rate as the crank pulley
pm or email me; one_tuffz@yahoo.com
pic makes it look a bit worse. can be installed as is or paint / powdercoat.
shows longer bolt and allen head screws
