1 tuff z Posted November 7, 2009 Share Posted November 7, 2009 i have an aftermarket a/c single v-groove pulley available. if you cover shipping and what i paid to have it blasted and plated [$5] it's yours. it was made to fit inside of the inner diameter of the stock crank pulley and comes with a longer bolt, which goes through it and the crank pulley to attach it. it also has 2 allen head screws that go though it into factory tapped holds outboard of the center hole to keep it spinning at the same rate as the crank pulley pm or email me; one_tuffz@yahoo.com pic makes it look a bit worse. can be installed as is or paint / powdercoat. shows longer bolt and allen head screws Quote Link to comment Share on other sites More sharing options...
letitsnow Posted November 8, 2009 Share Posted November 8, 2009 Where do you get things plated? General plating on st. paul? Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted November 8, 2009 Author Share Posted November 8, 2009 rochester overnight plating on cairns street. Quote Link to comment Share on other sites More sharing options...
