S130Z Posted November 15, 2009 Share Posted November 15, 2009 So after searching high and low, and trying multiple combinations of wiring, I am at a total loss. I am running MS II 3.57 with the coil driver installed. I am running the stock turbo ignition with MSD Blaster Coil(if that makes a difference). My problem is I am getting no tach signal to MS or my tach. I have my factory wiring harness in my 83 ZX removed. As I read, you must connect the blue wire comming from the coil back to the resistor inside the cab. I have done this and got no signal. Any help is greatly appreciated. Adam Silver Quote Link to comment Share on other sites More sharing options...
S130Z Posted November 16, 2009 Author Share Posted November 16, 2009 I figured it out guys. My shielded wire from MS was grounding out the voltage signal because the shielding was touching my soldered point. I hope this helps anyone in the future. Quote Link to comment Share on other sites More sharing options...
