afbrian13 Posted November 17, 2009 Share Posted November 17, 2009 I didn't know if this should go here or in the V8 thread, but I figured it would require more body work than engine. Does anybody have a shaker scoop on a Z? I was thinking of one off a newer Mach 1 'stang, and I saw one from a 70's firebird on craigslist. I think it would look pretty cool on a z with the hood bump already there. Kinda kills the sleeper idea if your going for that. So any pictures/decriptions of one? Lets see it! Quote Link to comment Share on other sites More sharing options...
bcdavis Posted November 19, 2009 Share Posted November 19, 2009 I have one on my Dodge Magnum, so I can give some insight. The shaker intake is actually pretty easy to adapt to fit several types of engines. If you have a v8 conversion on your Z, then you just have to cut holes for your carbs and you are ready to go. If you have a stock engine, it would still work if you are handy with fiberglass. Check out this pic : The small box on the front side is where the stock air cleaner resides. So the tube coming from the back of the shaker simply supplies the stock airbox with cold, fresh air... Then it just goes into the stock intake. So something like that could be fabbed up for a z, if you were good at fabrication.... Quote Link to comment Share on other sites More sharing options...
