Request for NA w '81zxt Ign. MSII Settings
evil_datto
Hi guys, I've purchased the stuff and so now I'm looking for settings to start with once I get it all wired up.
The car is as follows:
MSII 3.0
'80zx N/A
Highish compression 10-11:1+
Stock cam (for now)
'81zxt ignition components (Power transistor & Crank Angle Sensor on crank pulley)
Adjustable FPR
Headers
2 1/4" exhaust
No O2 sensor for now. I have the sensor, but unable to get to the exhaust shop to get a bung welded on the headers for it at the moment.
I've looked through the Map sharing thread but didn't find any N/A's that fit my situation very well.
Also didn't see anyone running MSII with the '81zxt CAS & Power Transistor so I don't know what settings to use to run them. Hoping someone can send me their file so I can grab those ignition settings.
For the timing map, I can't use anyone's N/A maps because they will be running vac/mech advance, right? And the people with CAS are running timing for turbo.
Fuel map just a normal map I guess? Nothing special on the fuel delivery side, just stock N/A 180cc Injectors.
Please share any information you think might help me with my setup.
Thanks, Scott.
Requesting again for any setups that are close to mine, I don't mind having to tweak on an existing setting file.
Or if someone can point me to some existing setups I might have missed.
To make it simple,
I basically only need full settings for a near stock N/A with spark.. But can't find anyone using spark on N/A.
For the spark I need the ignition settings to suit 81zxt components
I'm using 2.89 code on MSII 3.0
Thanks, Scott
Hey, this is the thread we have here for Z MS tunes:
http://forums.hybridz.org/showthread.php?t=99689&highlight=Map+sharing&page=2
Read all the way through that, and while you're at it, check out the MegaSquirt forums. http://forums.hybridz.org/forumdisplay.php?f=88
Anyways, ZManco is running MSII Extra on a N/A L28 using the ZXT CAS Dizzy, here are his maps:
http://forums.hybridz.org/showpost.php?p=930907&postcount=30
You can extrapolate the data and suit it to your needs if things aren't 100% like yours, this will just get you started and you can tune out the rest.
