vega Posted November 26, 2009 Share Posted November 26, 2009 So I've been playing around with this tire size calculator; http://www.wheelsmaster.com/rt_specs.jsp Though I guess I just have a quick question with the stock rime (I have the Iron Cross rims) on my 1978 280z 5spd car- what is the widest tire I can fit on that rim (with recommended height accordingly). I may be incorrect but from my understanding it is a 6" by 14" rim though I could be wrong. Also from what I can find 195/60r14 tires were the stock sizing (tire-rack). I had purchased the car with lower profile tires (which look not quite right imho)- I prefer wider taller muscle car styled tires with performance in mind. Thank you in advance to any help that may be provided vega- Quote Link to comment Share on other sites More sharing options...
vega Posted December 1, 2009 Author Share Posted December 1, 2009 bump Quote Link to comment Share on other sites More sharing options...
Gcontrol Posted December 10, 2009 Share Posted December 10, 2009 I have used 215-60-14 which have 24.2" Overal diameter(O.D.) on my 79 280zx with the Iron cross wheels. Stock tire O.D. is 24.8" I have a friend who has 225-60-14, 24.7" on the same wheels on his 280zx. Quote Link to comment Share on other sites More sharing options...
Zmanco Posted December 10, 2009 Share Posted December 10, 2009 Some tire manufacturers will list the min tire width for each tire size. Here's the specs for a BFG tire in a 215/60-14: http://www.tirerack.com/tires/Spec.jsp?make=BFGoodrich&model=Radial+T%2FA&vehicleSearch=false&fromCompare1=yes&partnum=16SR4RADTARWL2&tirePageLocQty=%26partnum%3D16SR4RADTARWL2 In general, I wouldn't go beyond a 215 for a 6" rim, and even that is probably pushing it, although this example tire seems to be ok with 6" rims all the way up to 235. FYI, the width of the tire to our eyes is affected obviously by the tire's width, but also a lot by the width of the rim it's mounted on. In other words, a 215 vs 205 tire on a 6" rim aren't going to look much different. And all else being equal, I'd bet that the 205 would be a better choice from a performance point of view. Lastly, here's a spread sheet I built that let's you see how the tire diameter changes for a variety of sizes for our Zs. The Error column is how much your speedo will be off, assuming it's accurate with the stock tire Tire sizes - 240z.zipUnavailable Quote Link to comment Share on other sites More sharing options...
310z Posted December 11, 2009 Share Posted December 11, 2009 205-60-14 would look very nice and you would not have ware issues related to the tire being to wide. They look really fat on a 14 in. wheel. Old school cool. Quote Link to comment Share on other sites More sharing options...
vega Posted December 11, 2009 Author Share Posted December 11, 2009 will the 205 60 14 fit in front also? got pics? Quote Link to comment Share on other sites More sharing options...
Gcontrol Posted December 11, 2009 Share Posted December 11, 2009 205-60-14 would fit great with no issues in front. pic size is too big to upload. vega said: will the 205 60 14 fit in front also? got pics? Quote Link to comment Share on other sites More sharing options...
Gcontrol Posted December 11, 2009 Share Posted December 11, 2009 BFG tires usually run wider than other brands. Quote Link to comment Share on other sites More sharing options...
vega Posted December 11, 2009 Author Share Posted December 11, 2009 Link to pic? put it in photobucket Quote Link to comment Share on other sites More sharing options...
310z Posted December 12, 2009 Share Posted December 12, 2009 vega said: will the 205 60 14 fit in front also? got pics? I do not have that tire size. However, I have seen 205-60-14 fit on a stock car without problems. The tires I saw, were Yokohama ES100 on the car. If they have your size The Tire Rack is doing a close out on them right now. Quote Link to comment Share on other sites More sharing options...
Zmanco Posted December 12, 2009 Share Posted December 12, 2009 A long time ago I ran 215/60-14 BFGs on 14 x 7 Enkei wheels. I had no clearance issues front or rear on my 73. The suspension was stock. I can't imagine you'd have clearance issues with a 205/60-14 unless something isn't straight on the car. Quote Link to comment Share on other sites More sharing options...
vega Posted December 12, 2009 Author Share Posted December 12, 2009 I get a deal on bridgestone/firestone tires 10% above cost not install cost and no balance cost. Quote Link to comment Share on other sites More sharing options...
Gcontrol Posted December 13, 2009 Share Posted December 13, 2009 These guys sell 205-60-14 as low as $40 a piece! No sure how much it would cost to ship though! http://www.onlinetires.com/user/vehicle/tires/allbrands.html Quote Link to comment Share on other sites More sharing options...
