Randalla Posted December 10, 2009 Share Posted December 10, 2009 Having just changed out the stock air cleaner and filter for the much more free flowing ITG's I now find I'm flowing so much air that the engine seems to be choking when I accelerate from idle. The ITG's are oiled foam filters and I am running aluminum air horns inside them. Clearly I need to get more fuel to the carbs to offset all the fresh air the carbs are now receiving. My thoughts at this point are to richen up the fuel mixture by turning the screws out a little bit at a time, drop the needles into the piston slightly to more quickly get fuel off idle and if that does not work satisfactorily, experiment with some different profile needles. Has anyone experiened this issue and what did you find that worked??? The engine has stock internals with no other real perfomance mods. Quote Link to comment Share on other sites More sharing options...
at-jefft Posted December 10, 2009 Share Posted December 10, 2009 If it is leaning out on accelleration, then turning the mixture knobs on the bottom will work. Quote Link to comment Share on other sites More sharing options...
