72' 240z Restoration/Build
Taken from my local automotive site http://www.vadriven.com
Ever since the first time I saw a 240z, I knew I had to have one. Well, now I do. Previously- every car I'd looked at was a rustbucket, or a shitpile. This particular car has been a southwestern car for most of its life- leaving it pretty much rust free. The body is straight, the frame rails are solid, the paint is shiny- hell even all the rubber boots under the car are rip-free. The motor (which I'm still researching) is a re-built (yes, paperwork) later 2.8L L28 motor with a P90 head. Should get me somewhere around 190-200ish Hp. For now... ;)
The previous owner of the car had a little wiring mishap and decided to replace the entire harness, but stopped before ripping it all out. Luckily, I studied electronics etc. for four years in tech academy- and have been messing with car wiring for quite a while. The PO purchased an 'E-Z wiring' kit for the car and after reviewing the instructions, schematics, and the harness and car itself, I believe this is a job I can tackle.
With that being said there will be ALOT going on with this car and I'm beyond stoked to be doing it.
♥♥♥♥♥♥♥ shitty camera died. MOAR when I can find someone to come shoot some pichas
First step is to clean up and prepare for everything. I'm going to be exposing what little rust there is on the floorboards- then sealing it with either POR-15 (or something like it) or some of that rubberized sealant. All of the sound-deadening is well, shitty and that's all gonna go. After the interior is sealed/painted I'll be moving to the engine bay and pulling the motor and preparing for wiring... but thats down the road.
  • 3 weeks later...
That is very nice.
Thank you- I've been slacking on updates here due to the lack of real interest in the project.
Here's the dash and it's harness. Now it's totally 'un-wound' and I'm using it to integrate with my EZ-harness.
Headlight/turn wiring, pass side
firewall hole pass side
harness accross interior firewall
rear lighting, fuel system ect yet to be run, pass side
engine power wiring, fused circuits
fuse box
steering column
ignition
before grinding
I just dropped the car off to get the floorpans installed, more to come!
  • 4 weeks later...
