streeteg Posted December 16, 2009 Share Posted December 16, 2009 OK so here is the story---- Below is a pic of the exhaust side of an RB26block stripped in preparation for a full race single t4 turbo kit. Each piece either flows oil, coolant or vacuum, and I was curious to know which was which in regards to oil feed, return, water feed and return and vacuum. Going from 2 turbos to one threw me for a loop--- any insight? Also, There is another coolant line that wraps to the front of the block that goes into the thermostat. For those curious the car is a r33 skyline. Anyway, the different lines are numbered 1-6. If you have done a single turbo conversion and can give me some insight on what numbers you used for your feeds if any that would be great. THanks guys Eric Quote Link to comment Share on other sites More sharing options...
gmac708 Posted December 18, 2009 Share Posted December 18, 2009 #1 oil return from turbo #2 oil supply to turbo #3 oil return from turbo #4 water from turbo. This also T's to that line that wraps around front. #5 boost pressure to waste gate actuators #6 sense line from turbo inlet to boost pressure control solenoid. Your water supply line is just below the back two exhaust ports. Hope that helps. Quote Link to comment Share on other sites More sharing options...
streeteg Posted December 18, 2009 Author Share Posted December 18, 2009 Thanks man...I have been following your build for a while- Car looks great. I am definately going to pick your brain about your coilover install as thats my next thing to do. Regardless thanks for the help We are gonna attempt to complete the rest of the install this weekend. Ill keep everyone posted. -Eric Quote Link to comment Share on other sites More sharing options...
blitzkreig Posted January 3, 2010 Share Posted January 3, 2010 #2 oil supply to turbo what size threaded fitting is the oil supply? Quote Link to comment Share on other sites More sharing options...
gmac708 Posted January 6, 2010 Share Posted January 6, 2010 Here is what I'm pretty sure came with the RB26DETT Oil supply had a "T" fitting in block. This shows restricter in Banjo bolt. The hole in the end is way bigger than the hole up inside the bolt. I'd say the restricter hole is about .030" or less (I did not measure it). And the water supply. These stock "T" fittings have Concave seats, so if you plan on using the stock "t" fittings and need adapters for AN type hoses... I used Male 14 X 1.5 MM Metric concave seat to 6AN Male steel p/n 3276-004 for water. Male 12 X 1.0 MM Metric concave seat to 4AN Male aluminum p/n 3276-020 for oil. At Pegasus. Or...you could just try and get adapters that screw into block and go AN fittings all the way. I hope this helps. Gord Quote Link to comment Share on other sites More sharing options...
TurboSE Posted January 8, 2010 Share Posted January 8, 2010 correct me if I'm wrong....running a single you'd really only need to use #1 or #3, not both. Quote Link to comment Share on other sites More sharing options...
gmac708 Posted January 9, 2010 Share Posted January 9, 2010 correct me if I'm wrong....running a single you'd really only need to use #1 or #3, not both. Correct. You could even plug/cap both of #1 and #3 and drain into the oil pan if you welded a bung on side of pan. All the same. Quote Link to comment Share on other sites More sharing options...
TurboSE Posted January 9, 2010 Share Posted January 9, 2010 I actually found that answer in another thread by this threads OP...a few more questions: I'm currently planning to run a Greddy T78 (that could change), could I just come out of #2 with an adapter to 4 AN line into the turbo? What size fitting is #1? Quote Link to comment Share on other sites More sharing options...
gmac708 Posted January 9, 2010 Share Posted January 9, 2010 I actually found that answer in another thread by this threads OP...a few more questions: I'm currently planning to run a Greddy T78 (that could change), could I just come out of #2 with an adapter to 4 AN line into the turbo? What size fitting is #1? #2 to turbo. Make sure you get fitting with restricter. Here are some links I found helpful. Not familiar with T78. http://www.atpturbo.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=tp&Category_Code=ATP-OIL2 http://www.pegasusautoracing.com/advcat.asp?CategoryID=PLUMADAPMETRIC&iorb=4764&utm_source=Sponsored%2BSearch&utm_medium=PPC&utm_campaign=BROI http://www.aptuning.net/Turbo_Fittings_s/158.htm I'm not sure about #1. It is a pipe thread. Quote Link to comment Share on other sites More sharing options...
blitzkreig Posted January 9, 2010 Share Posted January 9, 2010 #2 to turbo. Make sure you get fitting with restricter.Here are some links I found helpful. Not familiar with T78. http://www.atpturbo.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=tp&Category_Code=ATP-OIL2 http://www.pegasusautoracing.com/advcat.asp?CategoryID=PLUMADAPMETRIC&iorb=4764&utm_source=Sponsored%2BSearch&utm_medium=PPC&utm_campaign=BROI http://www.aptuning.net/Turbo_Fittings_s/158.htm I'm not sure about #1. It is a pipe thread. is the restrictor used only on bb turbos? I will be fitting a BEP s366 ett and Tony @ T1 said it is not necessary. Quote Link to comment Share on other sites More sharing options...
TurboSE Posted January 9, 2010 Share Posted January 9, 2010 awesome links...thanks! Quote Link to comment Share on other sites More sharing options...
TurboSE Posted January 15, 2010 Share Posted January 15, 2010 Single Turbo Swap Plumbing Greddy T78. Greddy T78, non-water cooled, non-BB. External wastegate...will these work? #1 oil return from turbo - 3/4BSP or 3/4NPT? Is 12AN too big for an oil drain? #2 oil supply to turbo - M12x1.0 to 4AN? Do I need a restrictor for non-BB? #3 oil return from turbo - Blocked. #4 water from turbo. - Not needed for non-water cooled turbo? #5 boost pressure - To external wastegate? #6 sense line from turbo inlet to boost pressure control solenoid - To boost controller? #7 water to turbo - Blocked on non-water cooled turbo? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
