78nismoZ Posted December 16, 2009 Share Posted December 16, 2009 As the title says my auto tranny just kicked the bucket and I need to replace it asap. I have my 78 5spd and driveshaft, my question is will it fit into the 81' or what do i need? Sorry I am sure that this has been covered, but I searched and I wasnt sure what kind of combo to type in the bar to get my results, so any help is great....thanks very much! Quote Link to comment Share on other sites More sharing options...
Kash Posted December 16, 2009 Share Posted December 16, 2009 Should bolt right in but you will need the cross member from the '78 trans... Quote Link to comment Share on other sites More sharing options...
78nismoZ Posted December 17, 2009 Author Share Posted December 17, 2009 are the drive shafts between the 78 and 81 different lengths when they are manual? Quote Link to comment Share on other sites More sharing options...
IdahoKidd Posted December 17, 2009 Share Posted December 17, 2009 You'll need pedals, clutch master, clutch slave, flywheel and clutch too. Quote Link to comment Share on other sites More sharing options...
drzed Posted December 17, 2009 Share Posted December 17, 2009 Make sure you have a pilot bearing in the back of the crank. Most already do. The driveshaft is not the same length but it might work. I have used a 280zx turbo drive shaft in an earlier car (S30) but it is about 1/2" too long. In your case it should be 1/2" too short but may still work in a pinch as long as enough of the splines are engaged in the trans. You wouldn't want the to fall out on the road! Pole vaulting anyone? As mentioned above you still need flywheel, clutch, throw out bearing/holder/fork, clutch master/slave/line, pedal, shifter and probably lots of misc items I have forgotten. Good luck with the swap. Quote Link to comment Share on other sites More sharing options...
78nismoZ Posted December 17, 2009 Author Share Posted December 17, 2009 thanks guys. I should of been more clear I know about the clutch and everything just curious about the trans and stuff but thanks guys Quote Link to comment Share on other sites More sharing options...
78nismoZ Posted December 18, 2009 Author Share Posted December 18, 2009 This thread can be closed. I went to the junkyard today and got everything I needed and while I was there I met a gentlemen that gave me a free 81' 280zx 5spd trans that was recently rebuilt. Quote Link to comment Share on other sites More sharing options...
Pyro Posted December 18, 2009 Share Posted December 18, 2009 don't forget to take off the flexplate spacer at the end of the crank before bolting on the manual flywheel. Quote Link to comment Share on other sites More sharing options...
78nismoZ Posted December 18, 2009 Author Share Posted December 18, 2009 thanks pyro. i will make sure i do. Quote Link to comment Share on other sites More sharing options...
Kash Posted December 20, 2009 Share Posted December 20, 2009 78nismoZ said: This thread can be closed. I went to the junkyard today and got everything I needed and while I was there I met a gentlemen that gave me a free 81' 280zx 5spd trans that was recently rebuilt. Not a bad day... Quote Link to comment Share on other sites More sharing options...
Gcontrol Posted December 20, 2009 Share Posted December 20, 2009 78nismoZ said: This thread can be closed. I went to the junkyard today and got everything I needed and while I was there I met a gentlemen that gave me a free 81' 280zx 5spd trans that was recently rebuilt. Lucky you! Quote Link to comment Share on other sites More sharing options...
