Missing the plug for my 83 turbo dizzy, trying to figure out what prong is what.
LamboZ
I'm missing my plug for my turbo dizzy and I need to wire it up to my MSnS.
Now there's 4 prongs and I know I gotta use all but one but I'm stumped on what one is what. I searched and there's no answer that helps me on this.
Most pictures I see aren't very clear either.
Any help would be great.
It's also in one of the stickys in the megasquirt forum.
It's in this one
http://forums.hybridz.org/showthread.php?t=88246
but there was only a verbal description which was a bit confusing to me.
DIZZY WIRE COLORS!!!
if you use the wire at the dizzy' date=' versus after the 4 pin round connector:
Dizzy side ------------ Harness Side
Red (12v) B/W
White (MS trigger) G/B
Green (not used) G/Y
Black (gnd) Black
In case your wires are unplugged from the base of the dizzy, here is some info from Mack:
if i hold the dist in my hand, with the rotor pointing away from me and the plug facing up, the green wire is above the white wire on the left and the red wire is above the black on the right. [/b']
