280ZX Headlight Wiring
Guest EnthuZiast
Guest EnthuZiast
I've got a '79 280ZX and am thinking about some halogen or xenon lights for it. Do I need to modify the wiring on the lights for this like the 1st generation cars or not?
Thanks
If you upgrade to higher wattage bulbs then you will need to wire some relys. You'll burn out the switch eventually if you don't. If you use some bulbs that are Xenon or something but, go with a set that are very close to stock then you won't have any proublem.
I saw a set of Xenon at Target for 12.99.
