Anybody had a cam with scratched journals repaired?
Evan Purple240zt
I have an 02 WRX that spun a rod bearing (bought the car like that) and debris made it into the head and scratched the cam journals up and also did some damage to the heads. The heads are easy to replace, but may still be serviceable if I can get the cams repaired.
Why not get new cams you say? Well turns out this engine has stage two brian crower cams and I would REALLY like to use them.
What say you hybridz? I can get photos tonight of the damage.
Evan
I'm not an expert on the subject by any means, but it seems like, if you were to use them, they would eat through lash pads quickly, depositing metal shavings in to the oil. You may be able to have them welded up and reground, though. However, I think at that point, it would be cheaper to just buy new cams.
