OUT-LAWZ Posted January 4, 2010 Share Posted January 4, 2010 Need your help quys, I installed Triple weber DCOE 40 on my engine and i found that only one weber was working (Cylinder 5 & 6). then i removed , cleaned and put them together again and when i started the engine stayed for 5 minutes working fine then back again to the same problem, any idea what is going on? Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted January 4, 2010 Share Posted January 4, 2010 Rebuild them with the full rebuild kits if they are old. Sounds like your float bowls are either overflowing or running dry. Could be due to bad floats or stuck needle valves. Quote Link to comment Share on other sites More sharing options...
MikeyZee Posted February 3, 2010 Share Posted February 3, 2010 You may be able to switch the carbs around and see if it's the carb or a fuel delivery issue. Check your filters too. A fuel pressure gauge might give you a clue too. Quote Link to comment Share on other sites More sharing options...
