Strapping points
olie05
the LCA's are fine for strapping the rear of a Z, it helps control the rear tire movement under WOT pulls. the idea is to control the tires, by binding the bodywork you leave the entire suspension to shift around during the pull. if you have the ability to grab out near the wheels it eliminates alot of the cars ability to shift around during a pull.
