zwilson2148 Posted January 23, 2010 Share Posted January 23, 2010 okay yesterday i posted fuel problem. I think i found the problem. when i mess with the mass air flow meter i can get the car to run better. the problem is when i step on the gas the air flow meter weight goes to far and it floods out.. but when i rev it and push the meter slightly back i can rev the engine just fine it runs nearly perfect how can i fix this problem? THANK YOU ALL FOR ALL OF YOUR HELP Quote Link to comment Share on other sites More sharing options...
stravi757 Posted January 24, 2010 Share Posted January 24, 2010 You can tighten the spring on the AFM. But if the AFM has never been messed with before then either the AFM is going bad or your problem lies somewhere else. Quote Link to comment Share on other sites More sharing options...
zwilson2148 Posted January 24, 2010 Author Share Posted January 24, 2010 How do you tighten the spring? is it moving the black wheel a few notches or is there some other way? Quote Link to comment Share on other sites More sharing options...
