BLKMGK Posted August 5, 2001 Share Posted August 5, 2001 Do you have the JTR book? It's got the wiring in it for the V8 swap. What year is your car? Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 5, 2001 Share Posted August 5, 2001 Boy, the best advice I coould give is to search the other forums, like the ignition one, for such things--look at remote selenoid discussions. Hopefully, that will answer your questions. If the wiring is really bad, ytou may just have to get a painless system, but that does run a few dollars. Good luck. David Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 5, 2001 Share Posted August 5, 2001 Thank you for your replies. I found the problem. It was the alternator wire from the starter that had come out of the crimped thingy (lol, I don't know the name of the caps you crimp a wire into to put on a bolt). Anyway, I popped it on and it fired right up... Fixed a lot of problems with one wire. Oh well, thanks again. Richard Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 5, 2001 Share Posted August 5, 2001 Richard, I'm glad you found it. It always pays to look at the small connections first. I had a Datsun 200SX with electrical problems--all were simptoms of the faulty ground wire. Davy Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 5, 2001 Share Posted August 5, 2001 I bought my V8Z already put together. It was a bad job and I have been constantly fixing things all over the car. I have run into a big problem with the wiring of the car. There has always been a heat soak problem on the car, but now it won't do anything. I've replaced the battery to be sure it wasn't something that simple. But since then, I've lost all power like radio, etc... If someone could send me a quick wiring diagram or help me out some other way I'd appreciate it. I also need help with the wiring of the starter (I'm unfortunately unfamiliar with a 350 as I've been a rotary guy from the beginning). L8R Richard Quote Link to comment Share on other sites More sharing options...
