seam between 1/4 windows and hatch
Guest Anonymous
Yep. That's the place where the body is soldered together at the outer surface. There are several layers of steel in that area, as can be seen in the Datsun Shop manual. The inside is welded together.
I think a good thing to do would be to melt out all the solder and Mig weld the area and grind/smoot it down. Wished I'd done that. It seems the street rodder guys do this all the time.
Pete Paraska - 73 540Z - Marathon Z Project - pparaska@home.com">pparaska@home.com -
