Thermostat Hose for 280ZX 1982 Leaks
oldschool2
I had the exact problem, and mine was squirting on my engine while i was driving and i kept smelling something as if it were burning under my hood. I even pulled over a fews times to check but found nothing. I had thought it was the cars passing me then.
Eventually, i found it was the exact house. (i have the same car year, model.)
The hose had such a small pin hole, that it wouldn't squirt unless the engine was warmed up completely, which was until you start to drive. I later found the problem, and then i went to auto zone where they gave me a free hose for it. Problem fixed.
Eventually all the rubber will need to be replaced...from a different time to another. Do i buy all of it now, or do i take it one step at a time lol? That's what i ask myself.
To be safe, make sure ALL your rubbers are good (radiator & heater hoses, vacuum hoses, tires, and that thing some guys keep in their wallets in case they get lucky) :lmao:
I had to raise the hood and rev the engine to find my leak. It was a pin hole about dead-center at top of the hose. A royal mess to clean-up.
That's unfortunate then. I had to clean up just a bit, as when the leak sprayed, it sprayed upwards onto the hood :rolleyesg
It was kinda silly, but it cleaned my hood a little bit lol.
