Guest Anonymous Posted October 11, 2000 Share Posted October 11, 2000 I've decided to get one of Motorsport's front air dams for my 240. The one I've chosen requires turn signal relocation. I was wondering if anyone in the group had a source for a small signal lamp that would fit somewhere in the grill area. Thanks, Jeff ------------------ '71 240 '91 TBI 305,700R4 w/ shift kit Quote Link to comment Share on other sites More sharing options...
Owen Posted October 11, 2000 Share Posted October 11, 2000 I really like the euro spec 260Z turn signals mounted in the grill. Owen ------------------ http://www.homestead.com/s30z/index.html Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 11, 2000 Share Posted October 11, 2000 If its a light thats going to be frenched in (flush) you might try a look through some of the Harley mags or suppliers (http://www.j-pcycles.com) for the LED array strips they use on the back of wide Harley fenders, they're thin, extremely bright and look great flushed into a panel. Downside (as always) is they're about $72.00 apiece, the rod guys use em too, may be cheaper, but I donno, only thing more expensive than Harley parts is Rod parts (but cheaper than aviation and rocket parts! ) If I misunderstood where you were putting the lights, consider this just me babbling, but they would look good on a Z airdam. Regards, Lone Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 8, 2000 Share Posted December 8, 2000 Is it possible to use the later in grill turn signals from a 280 Z on a earlier 240-260 Z do the brackets mount up well on the earlier cars? Quote Link to comment Share on other sites More sharing options...
Drax240z Posted December 8, 2000 Share Posted December 8, 2000 I would think that if you were relocating to the grille area, nearly any signals you can find could be used! You'll have a small amount of customizing for the grille and a bracket goes, but it shouldn't be very hard at all. I believe 99% of turn signals are the same when it comes to the wiring end. My advice is to search the local wreckers for something you like and go for it. (I'd take into consideration how easy it will be to find a replacement though) ie: don't use the ferrari ones, use the toyota ones. ------------------ "Gimme Fuel, Gimme Fire, Gimme that which I desire" -Metallica Drax240z 1972 240z - L28TURBO transplant on the way! http://members.xoom.com/r_lewis/datsun.html http://members.home.net/drax77/newpage.html Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 16, 2001 Share Posted January 16, 2001 quote: Originally posted by AZ240V8: I've decided to get one of Motorsport's front air dams for my 240. The one I've chosen requires turn signal relocation. I was wondering if anyone in the group had a source for a small signal lamp that would fit somewhere in the grill area. Thanks, Jeff Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 16, 2001 Share Posted January 16, 2001 quote: Originally posted by AZ240V8: I've decided to get one of Motorsport's front air dams for my 240. The one I've chosen requires turn signal relocation. I was wondering if anyone in the group had a source for a small signal lamp that would fit somewhere in the grill area. Thanks, Jeff I have a Motorsport air dam on my '77.I bought a set of brushed aluminum turn signals from WIRE-WORKS in Chester PA.They were $85.00 a pair.I made a set of brackets and mounted them below what you could call the bumper molded into the fiberglass.The companys web address is WIRE-WORKS.COM.Their phone number is (610)485-1937.If you'd like I'll e-mail pictures of mine to you. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 23, 2001 Share Posted January 23, 2001 I got a set of 280 turn signals from the local wrecking yard, along with the 280 grill. It took a little grinding on my early 260, as well as drilling a couple of holes on each side to mount them- piece of cake! You might want to take the wire connectors as well. Good luck! Quote Link to comment Share on other sites More sharing options...
