Stroker info Question
steve260z
I'm installing the rear main seal. The L28 crank has a lip which butts up against the seal. The V07 has no lip. Everything I've read makes no mention of this difference. Do I need the rear main seal for a V07?? Use the L28 seal?
I have pic...FAQ states use the manage attachment button on here. Its nowhere to be seen. How do I put a pic up?
It doesn't make a difference. As for pictures, you click on the "Go advanced" button. Scroll down and you'll see the "manage attachments" option. You'll open it and browse to where your photos are. One suggestion is to use a power tool to reduce the picture in your folder to a reasonable size prior to posting. That way you don't end up with an enormous picture in the posting.
