Megajolt on a SBC?
MONGO510
I have done several searchs and have found very little info on the Megajolt lite ignition system. I found nothing on its use on a SBC.
Has anyone done this? I quess the MS system is about the same. Should I just use data from that system
I am curious about their trigger wheel mount and timing map.
Mongo
I have figured out all the previous questions but have another.
Will the late 260 tach work with megajolt?
What do I need to do to make it work?
Thanks for any info.
Mongo
The late 260Z tach is the three wire type which connects to the (-) terminal of the coil. The Megajolt system uses a wasted spark EDIS coil pack, so unfortunately you can't just connect the tacho the same way as with a single ignition coil.
Either you convert the 260Z tacho by removing/modifying the incoming signal filter on the tacho PCB, so it accepts the +12V square wave tacho signal supplied by the Megajolt box, or you could use a tacho adapter such as the MSD 8920, which is wired inbetween the Megjolt tacho out and the tach's input wire.
