thisismatt Posted February 15, 2010 Share Posted February 15, 2010 I'm looking for an R180 limited slip. Preferably one that takes circlip shafts, but I'd even be interested in one of those calmini/purenissan versions that required the bolt-in axles/stubs. Basically, either the kind requiring clip-in circlips or the bolt-in kind is fine. 115mm ring gear, post 8/76, 25 spline. Quote Link to comment Share on other sites More sharing options...
Dtsnlvrs Posted February 16, 2010 Share Posted February 16, 2010 Well, they are NLA here in the states, but RHDJapan still stocks them...two different types...A Cusco and a Kaaz http://www.rhdjapan.com/cusco-type-rs-lsd-limited-slip-differential-nissan-r180-29366 http://www.rhdjapan.com/kaaz-lsd-limited-slip-differential-s13-silvia-180sx-with-lsd-oil-58450 The pages may need to be refreshed but there they are. Quote Link to comment Share on other sites More sharing options...
thisismatt Posted February 16, 2010 Author Share Posted February 16, 2010 Dtsnlvrs said: Well, they are NLA here in the states, but RHDJapan still stocks them...two different types...A Cusco and a Kaaz http://www.rhdjapan.com/cusco-type-rs-lsd-limited-slip-differential-nissan-r180-29366 http://www.rhdjapan.com/kaaz-lsd-limited-slip-differential-s13-silvia-180sx-with-lsd-oil-58450 The pages may need to be refreshed but there they are. Are you sure those are 25 spline? I've seen the S13 R180's available on ebay, but seem to recall them being 27 spline (or at least not 25, I can't remember for sure). Either way, I was hoping to spend a bit less than $1000 Quote Link to comment Share on other sites More sharing options...
Dtsnlvrs Posted February 16, 2010 Share Posted February 16, 2010 thisismatt said: Are you sure those are 25 spline? I've seen the S13 R180's available on ebay, but seem to recall them being 27 spline (or at least not 25, I can't remember for sure). Either way, I was hoping to spend a bit less than $1000 The ones on E-bay are all for the R-200...those two that I linked are for the R-180 used in the open diff'ed 180sx Quote Link to comment Share on other sites More sharing options...
Dtsnlvrs Posted February 16, 2010 Share Posted February 16, 2010 I should specify...theCusco PN you are looking for is LSD 135 or LSD 136, the Kaaz PN is DAN 2010 Quote Link to comment Share on other sites More sharing options...
Cobra_Tim Posted February 16, 2010 Share Posted February 16, 2010 http://forums.hybridz.org/showthread.php?t=148771 This will be your best option if you have to stick with an r180... Quote Link to comment Share on other sites More sharing options...
thisismatt Posted June 13, 2010 Author Share Posted June 13, 2010 ^ Quote Link to comment Share on other sites More sharing options...
