WTB: R180 LSD / Limited Slip
thisismatt
I'm looking for an R180 limited slip. Preferably one that takes circlip shafts, but I'd even be interested in one of those calmini/purenissan versions that required the bolt-in axles/stubs. Basically, either the kind requiring clip-in circlips or the bolt-in kind is fine. 115mm ring gear, post 8/76, 25 spline.
Well, they are NLA here in the states, but RHDJapan still stocks them...two different types...A Cusco and a Kaaz
http://www.rhdjapan.com/cusco-type-rs-lsd-limited-slip-differential-nissan-r180-29366
http://www.rhdjapan.com/kaaz-lsd-limited-slip-differential-s13-silvia-180sx-with-lsd-oil-58450
The pages may need to be refreshed but there they are. :)
Are you sure those are 25 spline? I've seen the S13 R180's available on ebay, but seem to recall them being 27 spline (or at least not 25, I can't remember for sure). Either way, I was hoping to spend a bit less than $1000
The ones on E-bay are all for the R-200...those two that I linked are for the R-180 used in the open diff'ed 180sx
  • 3 months later...
