jm9308 Posted February 21, 2010 Share Posted February 21, 2010 Hello everyone, liking the new website. I just pulled out an 87 turbo manual off the local pick and pull, someone already had took out the ecu. Will be dropping it into my 85 n/a. Have an engine test stand ready to be fired up. My question is I was looking around on ebay for an ecu and people selling there swear that the serial number must match or else it will not work. Is this true? I know for my ford early 95 ecu's use a aluminum while late 95 use copper base connections outputting from the module. Thanks Again Quote Link to comment Share on other sites More sharing options...
boogalou1 Posted February 22, 2010 Share Posted February 22, 2010 On 2/21/2010 at 1:57 PM, jm9308 said: Hello everyone, liking the new website. I just pulled out an 87 turbo manual off the local pick and pull, someone already had took out the ecu. Will be dropping it into my 85 n/a. Have an engine test stand ready to be fired up. My question is I was looking around on ebay for an ecu and people selling there swear that the serial number must match or else it will not work. Is this true? I know for my ford early 95 ecu's use a aluminum while late 95 use copper base connections outputting from the module. Thanks Again This link should answer your questions - ECU Quote Link to comment Share on other sites More sharing options...
wthorne Posted February 26, 2010 Share Posted February 26, 2010 I am pretty sure that the 84 - 86 turbo manuel ECU's will work for those models and the 87-89 ECU's were diff. Make sure whether or not you have a cali or federal car! If you put the Cali ecu in a federal car your check engine light will stay on thats all. If its an auto car you have to get an auto ecu, manual dont matter you can run an auto ecu in a manual. Quote Link to comment Share on other sites More sharing options...
