painting inside of crosmember
tsumner
I'm rebuilding the front suspension on my 77-280. The crosmember has been sand blasted and is almost ready to paint.What is the best way to paint the inside areas of this piece? I plan on using por-15,suggestions anyone? tsumner
This might be very messy, but you could let the amount of POR-15 puddle in the inner areas and physically "swish" it around in there, turning the whole crossmember over by hand--it's out of the car still, right? I know it's messy, but the coverage should be exceptional inside. Just food for thought.
David
If you figure in the cost of the POR-15 (assuming you don't need it for much else) and your time, powder coating is a viable option. Your choice of color too! Thanks for suggesting that BLKMGK.
David
The shop I've used here will send it back for a redo if I see anything wrong when I pick it up. I had one piece with a thin spot and another with a chip - redone for free! They did explain that oil soaked parts like some of mine were sometimes won't take very easily even after sandblasting. I was still VERY impressed at my crossmember's job - it was nasty going in.
The shop should coverplug any threaded holes. Expect that tolerances will be a bit tighter due to the thickness of the coating. They may also have some coatings that are best for UV exposed parts, others that are more chip resistant, and they may have some WILD colors too! I wish I'd taken the time to get my front arms done, that was one of the only suspension parts I didn't do. It wasn't cheap (you can haggle sometimes!) but boy is that stuff tough - should stop rust cold.
Oh yeah - Eastwood makes a setup to do this. If you've got access to an old electric stove in the garage this is a good way to go I think. Figures I threw away my stove just before finding out what the coating was goingto cost to have done (ouch).
