Ebay Door Strikers
I found 1970-1978 Door Strikers on eBay and wondered if anyone knows anything about them or this seller.
http://cgi.ebay.com/ebaymotors/1970-1978-Datsun-240Z-260Z-280Z-Door-Strikers-2-pcs_W0QQcmdZViewItemQQhashZitem53df75dd6aQQitemZ360231329130QQptZOtherQ5fVehicleQ5fParts
Like many others, I have problems closing my doors and I was thinking new strikers might help.
Edit: It looks like there are several sellers with these same strikers on eBay. I haven't seen these before, I wonder if they're any good.
Edited by Bartman
http://cgi.ebay.com/...VehicleQ5fParts
Actually, those are 70-76 Door Lock Strikers. However, IMHO, I would bet that it is your Door Locks are what need to be replaced
http://www.thezstore.com/page/TZS/PROD/SBC1B04H/30-7421
I don't think its the locks. Read this thread that discusses the 'door slamming' issue: http://forums.hybridz.org/index.php?/topic/36105-fixed-the-door-slaming-issue
I don't think its the locks. Read this thread that discusses the 'door slamming' issue: http://forums.hybrid...r-slaming-issue
If you notice, later in that thread..Carl Beck pointed out what the underlying cause was...the door lock / latch itself. Now if it is a full resto // very nice car you are working on....mod the exhisting strikers, then save the coin for new strikers, locks mechanisms, dovetails the works..biggrin.gif
Hi datsunlover:
Just an interesting side note:
That first "bump" on the "latch" when new (at least on the 72 240-Z) - had a nylon sleeve on it (kind of a horse shoe shape). Over time, they either wear out or get brittle with age - crack and fall off.
At one point I attempted to find a plastics shop - that could reproduce the nylon sleeve ... but the cost of the molds needed for injection molding were just too high. In the process of attempting to remove that nylon sleeve from the one good latch I had, we managed to break the original sleeve.
After that nylon bumper falls off - then the metal to metal contact between the latch and the catch start to take effect. At any rate, your solution should work fine...
FWIW,
Carl B.
