sweetride2go Posted March 4, 2010 Share Posted March 4, 2010 I'm doing a VG30dett swap ('91), but the trans I am using doesn't have electronic speedo pikcup. Do I need a VSS signal for the engine to run properly with the factory ECU? If so, and I install a VSS into the transmission, my next problem is the truck is equipped with a mechanical speedometer. Could I run the VSS signal to an electronic Autometer speedo and then piggyback the signal to the ECU that way? Thanks Ryan~ Quote Link to comment Share on other sites More sharing options...
sweetride2go Posted March 4, 2010 Author Share Posted March 4, 2010 Or maybe I could use something like this? http://www.autometer.com/cat_accessoriesdetail.aspx?vid=114 Otherwise I guess I could wire in the Nissan VSS to the ECU and just drive it without a speedo? lol, no...... Quote Link to comment Share on other sites More sharing options...
