Guest JAMIE T Posted May 31, 2001 Share Posted May 31, 2001 http://www.alphalink.com.au/~donhill/detailso.htm Thought this would be interesting to those looking at G-nose's Jamie Deathstar Quote Link to comment Share on other sites More sharing options...
DavyZ Posted May 31, 2001 Share Posted May 31, 2001 His paint scheme impresses me even more than the G-Nose does! Very impressive car. I've seen pictures in various places on the web about that car--very sweet racing car. David Quote Link to comment Share on other sites More sharing options...
Guest MM_280Z Posted June 11, 2001 Share Posted June 11, 2001 Why does he have an R180 in a race car? I thought those were supposed to be weak. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 11, 2001 Share Posted June 11, 2001 When this first posted I asked myself the same thing, seems like a R200 would be more appropriate.. Lone Quote Link to comment Share on other sites More sharing options...
pparaska Posted June 11, 2001 Share Posted June 11, 2001 I've heard it's usually the spider gears that go. And I've heard the early R-180s (open or LSD?) had 2 spider gears and went to 4 for strength. If it's not a high powered car, some prefer the R180 for gear choice, and weight reduction. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted June 11, 2001 Share Posted June 11, 2001 The R200 is certainly stronger but the issue of strength has alway been in discussions of supporting a high hp/torque hybrid. This might be a race car but it weighs in less that 2100lbs and although it is or will be putting out 340+hp, it will be in the 9000 RPM range. Such an application has a completely different torque curve and how power is applied. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 12, 2001 Share Posted June 12, 2001 Maybe the LSD unit or the "locker" unit makes it stronger? It's the ring gear that is the difference in size here, right? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 15, 2001 Share Posted June 15, 2001 In some racing classes you have to use the r180 diff due to class rules, I noticed this mentioned on another site (http://www.zcar.com). The car of the month (october 2000) was running in the SCCA club racing class in michigan, he also has to use the stock 4spd transmission. Quote Link to comment Share on other sites More sharing options...
