1975 280z Air doesn't blow (vents)
The car won't blow air, hot or cold. It has factory AC & it doesn't matter if I flip the switch to AC or Fan, hot or cold.
It just won't blow anything. It used to, until one day it just stopped working.
Any ideas on where to look or if this is a subject that been covered a million times?
I searched, no luck.
Thanks, yes the fuses are all fine. Sorry I forgot to mention that.
So if you are saying your fan blower will NOT come on at all, and the fuse is fine, then I'd check the wires that are connected to your blower motor to see if you are getting power there. If not, then you might have a bad switch. If you do have power, you may have burned your fan motor out.
