Khesayc Posted March 12, 2010 Share Posted March 12, 2010 hi I'm new to the forums, to start this off well i have a 1975 datsun 280z that has sat since 1988 which i bought about 1 month ago. the car at the moment has su carbs on it because i did want to deal w/ the fuel injection stuff the car should be able to start however i cannot due to the coil only sending a spark twice. the 1st time is when i turn the key to ignition and the 2nd is when i let go of it. In between the is no sparks I'm not sure what is causing this, or wether it is normal for it to do that. can anyone please give me some advice on this and how to get the car started. i know there is fuel and air going into the chamber, i have not the timing but I'm sure the wires on the distributer are correct. thank you in advance Quote Link to comment Share on other sites More sharing options...
Zinpieces Posted March 13, 2010 Share Posted March 13, 2010 Try running a hot wire to the coil, bypassing the ignition switch. Could be as simple as a bad switch. Quote Link to comment Share on other sites More sharing options...
Khesayc Posted March 13, 2010 Author Share Posted March 13, 2010 i just tried your idea and saw that the moment i tap the coil it sparks and i have to let go and tap it again for it to spark again. Is it supposed to be like that or is it suppose to spark continuously? Quote Link to comment Share on other sites More sharing options...
Zinpieces Posted March 13, 2010 Share Posted March 13, 2010 Every time you tap the coil you are simulating the turning of the distributor. The lobes in the distributor opens and closes the points or triggers the magnetic pickup sending a signal to the coil to fire a plug. This is how firing order and ignition timing are controlled. Even with the engine just cranking you should see each plug wire fire as the distributor turns. Other common ignition problems include bad caps or rotor, weak condenser. The condenser is there to mitigate the arcing across the points. When you do see a spark is it yellow or blue. Yellow spark may indicate a weak coil. Check for dirt, cracks, loose connections, all these things can degrade the ignition circuit. Quote Link to comment Share on other sites More sharing options...
Khesayc Posted March 14, 2010 Author Share Posted March 14, 2010 thanks i think i figured it out. I think i found a short and fixed the wires and now its runs fine just the spark in the plugs seem really weak. gonna get those changed tomorrow to see how it goes. once again thank you every much. Quote Link to comment Share on other sites More sharing options...
