SilverWolf072 Posted March 16, 2010 Share Posted March 16, 2010 Well, I finally got the L28 wired into my car. It starts up and run's smooth but dies after about 5 seconds. I've checked the fuel pump and it seems to be fine, the spark seems to be fine, everything I've checked seems alright. Any suggestion on the most likely thing to make an engine kill? I'm fairly sure it's something electrical. The motor doesn't sputter out like it's starving or anything, it's a very instant kill like everything going to the engine shuts down entirely. As always, any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Jeff260z Posted March 18, 2010 Share Posted March 18, 2010 On 3/16/2010 at 7:29 PM, SilverWolf072 said: Well, I finally got the L28 wired into my car. It starts up and run's smooth but dies after about 5 seconds. I've checked the fuel pump and it seems to be fine, the spark seems to be fine, everything I've checked seems alright. Any suggestion on the most likely thing to make an engine kill? I'm fairly sure it's something electrical. The motor doesn't sputter out like it's starving or anything, it's a very instant kill like everything going to the engine shuts down entirely. As always, any help is greatly appreciated. Is this a carbs engine or fuel injected? Quote Link to comment Share on other sites More sharing options...
jaydunn905 Posted March 20, 2010 Share Posted March 20, 2010 Replace fuel filter. If you have the original clear plastic one, check to see if there is fuel in the filter when it dies. Suggest --- use a metal fuel filter--$2.50 at any Auto Supply store. Quote Link to comment Share on other sites More sharing options...
JayBee280 Posted March 28, 2010 Share Posted March 28, 2010 http://www.atlanticz.ca/zclub/techtips/fuelpump/index.html This is more than likey your problem. After years of sitting they build up all kinds of gunk. I drilled the whole filter screen out its been running great ever since. Im getting ready to replace my fuel filter again after running fuel injector and tank cleaner before every fill up the gunk gets up in the filter itself after a few thousand miles. Quote Link to comment Share on other sites More sharing options...
