6sec 6cyl Posted March 18, 2010 Share Posted March 18, 2010 Ok, so i know i've been harking around for some help with some coil spec's for a z32 coil with the ignitor. the information isn't being easy to find nor do i have the o-scope or really the budget to aquire one. So i'm beginning to think about the LSx series coils. Again the question pop's up can i still use launch control. But i'm gonna kinda give you some in site to what i'm working with and i'll let yall kinda give me the best choice to go off of. Megasquirt v3.57 L28 with stock bottom end 1mm MLS head gasket Custom intake with 2 sets of mustang svo #38 fuel injectors (in the works) Precision t3/t4 turbo 350 turbo transmission with transbrake (reason for launch control) This is some of the things that are done to this vehicle and as you can see this z isn't going to see the street much but the strip it will see on a constant basis. Thanks in advance for any inputs on this, James Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted March 18, 2010 Share Posted March 18, 2010 As long as you have a launch control input mod added, it'll work with any coil that doesn't have a mind of its own and keep firing if you cut the signal. The only systems that fall into this category are Ford's TFI and EDIS, and Toyota's VAST. LSx coils are just fine. Quote Link to comment Share on other sites More sharing options...
6sec 6cyl Posted March 19, 2010 Author Share Posted March 19, 2010 As long as you have a launch control input mod added, it'll work with any coil that doesn't have a mind of its own and keep firing if you cut the signal. The only systems that fall into this category are Ford's TFI and EDIS, and Toyota's VAST. LSx coils are just fine. Thank you so very much Matt! I've been searching for this answer for a while Quote Link to comment Share on other sites More sharing options...
