kjmracer14 Posted March 24, 2010 Share Posted March 24, 2010 I'm switching from the narrow band O2 to the wide band, what do I need to do after swapping them out before I start/drive the car? Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted March 24, 2010 Share Posted March 24, 2010 (edited) what do I need to do after swapping them out before I start/drive the car? Go into the Configurator, and set the O2 sensor input for wideband. If you are using a LC-1 there is a setting for it, 0.5-1.5 Lambda. If that doesn't answer your question, you'll need to provide a bit more detail on what you are trying to do. Edited March 24, 2010 by flatblack280 Quote Link to comment Share on other sites More sharing options...
FubarI33t Posted April 11, 2010 Share Posted April 11, 2010 I have a O2 issue. My widwband came off a 90's Volvo 4 cylinder turbo. Issue is, 2 solid white wires, and one solid black(ground) i don't want to hurt the MSII by puting the 12 volt for the O2 on the wrong white wire. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 12, 2010 Share Posted April 12, 2010 That sounds like a heated narrow band... unless there's at least two more wires you didn't tell us about. Quote Link to comment Share on other sites More sharing options...
FubarI33t Posted April 12, 2010 Share Posted April 12, 2010 No, it's a heated narrow band. This is the first time i have ever messed with wideband, i thought 3 were wide. not 5. Should my MSII have more then just one O2 wire for wideband? Quote Link to comment Share on other sites More sharing options...
