Cowl to Hood Panel rust problem
After getting several rust bumps on my Cowl to Hood panel I found the source of the problem to be water gathering in the foam rubber pads glued to the bottom of the panel.
I was able to salvage the panel but wondered the function of these pads in the first place. I have a 71 240z.Do they really need to be repaced and if so what would be a better material to use? icon_confused.gif
The only thing I can think of is to eliminate noise. I have also wondered if they are really needed. If so, I would look at some kind of rubber or even foam rubber with water repellant properties. Shoot, even Dynamat would work.
Davy
Thanks for quick response! The panel may act as a noise transmitter without some dampening, but who could notice over a V-8s
normal rumble? Anybody have other ideas?
Uncle Ed
