510rb25det Posted March 27, 2010 Share Posted March 27, 2010 no spark.. i checked the coils plug i have power n ground is good also change the spark plugs , cas, timing is right, injectors are working, still no spark Quote Link to comment Share on other sites More sharing options...
pat1 Posted March 27, 2010 Share Posted March 27, 2010 are you getting the negitive signal to the ignitor from the pcm? Do you have power at the coils? Are you getting - signal from the ignitor to the coils? There are 3 wires going to the coils. You have a power,ground and a signal wire from the ingitor. Is you pcm a manual or a auto transmission pcm? I have a auto pcm that I used on mine and there was a wire to the pcm that had to be grounded to start. It was the wire from the inhibitor switch from the auto trans range switch. I had sort of the same problem with mine but it would happen when I was driving it and then I would loose spark and the car would stall out and not start. My problem was the PCM. Quote Link to comment Share on other sites More sharing options...
510rb25det Posted March 27, 2010 Author Share Posted March 27, 2010 hey bro i do have signal to the coil, have power , have ground s1 harness just changed the ignitor, maf , cas and pcm or ecu ,still no spark plz help me i m going crazy Quote Link to comment Share on other sites More sharing options...
pat1 Posted March 27, 2010 Share Posted March 27, 2010 When you spin the cas by hand can you hear the injectors click? Who did your harness? I think the problem is in the wiring. You have swapped all the main sensors. I would grab a meter and check out all the wiring. There is a sticky at the top of the page. For some reason your not getting signal from the PCM. Quote Link to comment Share on other sites More sharing options...
510rb25det Posted March 30, 2010 Author Share Posted March 30, 2010 well find out few things today ecu checked on buddy car its good ignitor is good coil pack are good cas checked is good new thing no ground on coils there is power at coils plz help me another thing my ign key is giving me some prolems Quote Link to comment Share on other sites More sharing options...
macr32 Posted March 30, 2010 Share Posted March 30, 2010 On 3/30/2010 at 6:36 AM, 510rb25det said: well find out few things today ecu checked on buddy car its good ignitor is good coil pack are good cas checked is good new thing no ground on coils there is power at coils plz help me another thing my ign key is giving me some prolems there is a ground wire coming off the coil harness that gets grounded on the rear bolt of the rear coil bracket, make sure that this wire is not broken and that the terminal is clean. Quote Link to comment Share on other sites More sharing options...
510rb25det Posted April 1, 2010 Author Share Posted April 1, 2010 On 3/30/2010 at 7:22 PM, macr32 said: there is a ground wire coming off the coil harness that gets grounded on the rear bolt of the rear coil bracket, make sure that this wire is not broken and that the terminal is clean. well i have ground on coils but no spark man this rb is pissing me off Quote Link to comment Share on other sites More sharing options...
