alec77 Posted April 7, 2010 Share Posted April 7, 2010 (edited) the only way i know how the break this down is into 2 lists 1977 280z prod date 9/77 do not work 1)low beams 2)tail lights 3)right high beam 4)side signals) 5)all dash lights working 1)brake lights 2)turn signals 3)emergency flashers 4)left high beam i changed every bulb in the car as well as every fuse. im not sure what to do next. Edited April 7, 2010 by alec77 Quote Link to comment Share on other sites More sharing options...
leftover z Posted April 7, 2010 Share Posted April 7, 2010 (edited) Did this all just happen at one time, or did you get the car like this? I'm going to assume you replaced all the bulbs and fuses with new bulbs and new fuses. Did you clean the bulb holders and fuse holders? Check the fusible links. Next step is to check your light switch. Check it for corrosion, broken connections or loose wires. Take it apart and clean it. Use the search feaure. Light failure is VERY common on here. Good luck! Edited April 7, 2010 by leftover z Quote Link to comment Share on other sites More sharing options...
