Pulley notch
Well, I got all the correct parts for my car now and I got the timing close enough to run and drive easily but the timing isn't perfect so I looked all around the pulley and couldn't find the notch that's supposed to be lined up with the pointer. So I sanded all the way around it thinking maybe it got filled with the paint that's on the pulley and still nothing... What do you do if there's no notch on the pulley? Where did the notch go?
Pull your first spark plug and look in there at the piston. When its all the way up that's TDC. You can be a little off and still be fine just make sure its on the compression stroke by taking off your oil cap. Then check your dizzy...... but I am sure you knew that.
Hope that helps!
