wthorne Posted April 22, 2010 Share Posted April 22, 2010 I cant hardly get my 86t to start. I takes like 10 minuets of tapping the gas and then when it does crank you have to hold the gas until it warms up? Then it run okay? PLEASE HELP????????? would the chts cause a no start or flooded start? Maybe a bad ecu? Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted April 22, 2010 Share Posted April 22, 2010 (edited) if it runs ecu probably okay. chts usually shows up as bad running while warming up or after warm up. I'd start checking into the idle components and the air regulator. if the aar is stuck closed car isn't getting extra air during start. if unsure about the chts just change it. easy job cheap part. idle up solenoid and aux air contol. get the fsm from xenon for more info. Edited April 22, 2010 by roger.svoboda Quote Link to comment Share on other sites More sharing options...
