reusing floor pans from another z
So I have a donor 73 with after market floor pans rust free. And a 71 that I am building would it be unwise to cut the 73s floor pan out and put them in the 71 witch is need of floor pans. I would not be using the frame rails, I will be buying new, so if you have extra you want to sell let me know. I am not an expert on this topic so all positive advice is welcome.
73 has no roof 71 has roof
I cut the floors out of my parts car and used them in the one we are building, you've got the parts why not use them. Then again it depends what your plans are for the '73, get rid of when you are done or try to rebuild it too. Next I need to install the new Bad Dog frame rails.
Edited by Scott_M67
You should do some searches on replacing the floor pans so you have an idea of what is going to be needed... the chance that the pans from the donor car will fit perfect is pretty slim, so you will need to do some teasing of the metal to get them right. Also, if you are getting new rails anyway, bad dog rails is a good choice. Chances are, you aren't going to find many people who bought zed findings rails without using them, but I guess if you wait long enough, anything is possible.
The other question you need to ask yourself is, are you positive that the donor floor pans are rust free? A lot of times, if you chip away the factory "sound deadening" it will reveal rust underneath despite visual inspection of being clean of rust.
The factory pans have been replaced and I can see both sides of the after market pans no rust lucky me.
  • 3 weeks later...
