Bondo on plastic...can it be done?
ratedZ
OK this might be a stupid question but I have never worked with bondo so I really don't know. Anyway, I got a pillar mount for my gauges but they don't exactly fit. I had to heat the plastic and cut the excess to fit (some what) on top of the pillar trim. Now, I wanted to blend the edges of the gauge mount to the pillar trim so it looks like it's one piece. Then I would sand it smooth so there is no seam and paint the whole thing black. Would bondo hold up or would it just crack? If so what else could I use to smooth out the transition? Any ideas? If this don't work I'll have to get another mount so I can start over....which would really suck! malebitchslap.gif
Don't know how well bondo would hold up. That stuff also shrinks as it absorbs water with time too. I personally use Evercoat, it's a fiberglass resin epoxy kinda thing? Anyways, it's water proof and is applied just like bondo.
How about some silicone sealer?
Owen
Guest KraZ4spd
Yeah, that is some great stuff. It cures from the humidity in the air. It can be sanded. They advertise that you can even tap the stuff for bolts. I haven't tried this but I believe it.
I too have used the POR putty. IMHO, it is the best thing they have going. I have used it on plastic and to patch holes in the hatch lip of my Z. It cleans up with water, has a long working time and you can work the stuff with a wet hand.
RATEDZ-BONDO
GO TO A LOCAL BODY SHOP OR AUTOMOTIVE JOBBER
PAINT SUPPLIER, THERE ARE SEVERAL METHODS TO
REPAIR PLASTICS. ONE IS PLASTIC WELDING WHICH
USES A SOLDERING IRON AND PLASTIC RODS. THE
SECOND IS SPECIAL TWO PART PLASTIC GLUES. THESE
GLUES ARE DESIGNED SPECIFICALLY FOR AUTOMOTIVE
APPLICATIONS( USUALLY TWO CASES-FLEXIBLE PLASTIC
OR RIGID PLASTIC). ALL THESE METHODS CAN BE
SAND AND PAINTED. THESE MATERIALS ARE MADE FOR
BODY SHOPS AND MAY NOT IN GENERAL AUTO PARTS
STORES-LOOK IN YELLOW PAGES.
ALOHA,
SUNNY
