Guest Anonymous Posted December 1, 2001 Share Posted December 1, 2001 i am trying to find some hi temp that doesnt need to be cured. i am trying to get paint for my header and the paint i bought needs to be cured within 8 hrs of aplication and i dont have to much convidence that i can do that. thanks in advance Quote Link to comment Share on other sites More sharing options...
DavyZ Posted December 3, 2001 Share Posted December 3, 2001 quote: Originally posted by oscar: i am trying to find some hi temp that doesnt need to be cured... If you can find it at a speed shop, try VHT high-temp paint. I personally feel that the ones from Eastwood, et al, that need to be cured are probably the best, besides powdercoating which is the best if you can afford it. Davy Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 3, 2001 Share Posted December 3, 2001 FWIW, I have yet to find a spray on exhaust paint that lasts more than 5 or 6 heating/cooling cycles. I have a tin of paint that we use on our big 6000hp compressor engines' turbo housings that don't need to be cured. It is brush on stuff, but I haven't tried it yet on my headers. According to the label, it can withstand up to 1600 degrees, and you can only apply a second coat after a few days after the first coat was applied, so I infer from this that it does some serious curing in the mean time. When I get home I will get the product details if you are interested. Tim Quote Link to comment Share on other sites More sharing options...
dsommer Posted December 3, 2001 Share Posted December 3, 2001 Check out POR-15 high temp coatings. They claim up to 1400 degree heat resistance!!! David Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 5, 2001 Share Posted December 5, 2001 i am in the middle of south georgia the only speed shope i got has 10 differant styles if clear tailight urgh. i have to go to the coast this weekend i will see if i can find any VHT paint if not i will goeith por 15 i guess. thanks for the info Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 5, 2001 Share Posted December 5, 2001 tim could you give me the info on the brush on paint. sounds like something that would work. i used to be able to get black powder coating done for free but i moved so that is gone now. my friend worked on the assembly line for aircraft parts and he would just put parts on the conveyor belt they would get sprayed and baked and he would be at the end to grab them. Quote Link to comment Share on other sites More sharing options...
