Ineptitude01 Posted April 29, 2010 Share Posted April 29, 2010 Hey guys. I've been trying to get this one by myself, but I'm just stumped. I finished rebuilding everything about my 82 280ZX Turbo a few months back, and put about 1000-1500 miles on it with the stock 82 ECCS. I have, however, had a Z31 Turbo ECU, MAF, and related hardware sitting on my shelf for a while. I was waiting to really dial the car in, and get rid of all the little running issues before I tried the Z31 swap. I actually went through with the swap two weekends ago, since everything with the stock ECCS was working just fine. The car idled great, sounded much smoother, and I thought I was in for a good thing, but then I drove it. It was beautiful until it warmed up. As soon as the engine is hot, and exits closed loop, it becomes gutless and floods out (from the smell). If I disconnect the CHTS (no code for this, just something that should be putting it back in closed loop), the idle stabilizes, but the car is obviously undriveable (ask me about the fireballs!). My harness was in really good shape before I did this swap, and I had no major running issues or weirdness. I followed the swap guide sticky (and cross referenced with the version on xenons130) to the letter. The FPR operates correctly, I ran the two wires to the coil, spark is good, advance is so-so, but this hot running issue just has me scratching my head. I've tried another MAF and a just-remanufactured ECU, and it made very little difference. It looks like my first ECU had some spark advance problems that were fixed by the new one, but it changed nothing about this open loop thing. I'm still using the stock 280ZXT 1-wire O2 sensor. I bought an 84 3-wire, but haven't installed it yet. It's my understanding that it's just a heated sensor, and doesn't have drastically different outputs. The AAC is disconnected, but I left the other 2-pin connector on the VCM plugged in. Unplugging it keeps the car from idling well at all. Is it possible that since this is a California car/ECU, there's something screwed up with the EGR system that wasn't discussed in the regular swap guide? Most of my suppositions here are coming from the table on EF & EC-69 in the 83 ZXT FSM, combined with the ECCS section in the 84 ZXT FSM. Any help or insights would be greatly appreciated. Other possibly relevant data: Water cooled turbo + automatic radiator: The car runs slightly hotter than normal, at just above 50% on the temp gauge MAF wiring: I'm taking switched positive power from the B/W wire that went to the 3 pin AAC connector. (Suggested by the swap guide) Have not tried adjusting the MAF as per the FSM. The selector screw was broken on my first ECU, and I didn't have time last night. Thanks. Quote Link to comment Share on other sites More sharing options...
