Ignition system fault
I am having major annoying problems. I put the key in and jumper cable my car and it starts, then it runs fine, then I turn the key off and car stops and then battery drains somewhere. The starter will not engage when you turn the key and the PO has a button rigged to turn the starter so its turn key and push.
For one I want to revert the wiring back to the stock turn key and go. Is this a separate wire or something built into the engine or dash wiring harness?
Also why is the battery draining when I shut the car off? I don't know where to start!
I tried a new ignition switch and it made it better, like it doesn't drain the battery as soon as you put in the key it just does when you stop the engine now.
