Guest Anonymous Posted August 19, 2001 Share Posted August 19, 2001 95 LT1- i installed a 6a box and blaster coil. engine started right up, ran for about 30 seconds and died. would not restart. after lots of checking and double checking car started and again died after 30 seconds. i am 100% certain everything is wired correctly. when i test spark from coil by grounding white wire per msd intructions i get spark, so ignition box and coil are working. when i test coil wire when trying to start NO SPARK! could it be the ignition control module? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 20, 2001 Share Posted August 20, 2001 replaced module and its running now!!!!!! thats relly weard the module went at the same time i was installing ignition? Quote Link to comment Share on other sites More sharing options...
MYRON Posted August 21, 2001 Share Posted August 21, 2001 Glad to hear you got it going again. Your lucky it wasnt the optispark unit going out, those things are expensive! Myron Quote Link to comment Share on other sites More sharing options...
