welders
Guest 400 ci 280z
Guest 400 ci 280z
i am looking for a welder and was wondering if i could get the wire feed one and not the mig. i have to weld on sheet metal so will the wire feed work or not?
do not buy a gasless machine. Buy a Clarke MIG for $339. It comes with a regulator for that price. All you have to do is rent a tank. I have one of these MIGs in my restoration shop and three at my school. They are well worth the price.
WELDER-
THE REASON FOR USING GAS (NORMALLY 75% CO2 AND 25% ARGON) IS A MUCH SUPERIOR WELD. ALSO, THE FLUX FROM GASSLESS WIRE MUST BE WIRE BRUSHED OFF
AFTER WELDING. THE FLUX WILL FLAKE OFF AFTER TIME
AND NOT WORK GOOD. ALSO, WHEN WELDING SHEET METAL
USE ABOUT .024-.025 WIRE. IF YPU GET A 130 AMP
WELDER YOU CAN WELD ALUMINUM SHEET METAL. YOU JUST HAVE CHANGE TO 100% ARGON GAS AND USE ALUMINUM WIRE. IF YOU WANT TO WELD THICKER
ALUMINUM. YOU MUST AT LEAST 200 AMP WELDER.
ALOHA,
SUNNY
