Guest 400 ci 280z Posted December 26, 2001 Share Posted December 26, 2001 i am looking for a welder and was wondering if i could get the wire feed one and not the mig. i have to weld on sheet metal so will the wire feed work or not? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 26, 2001 Share Posted December 26, 2001 Check out this post.. It was discussed quite a bit. You can get (and it's what I have) a mig welder that can also weld gasless using flux cored wire. Tim Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 30, 2001 Share Posted December 30, 2001 do not buy a gasless machine. Buy a Clarke MIG for $339. It comes with a regulator for that price. All you have to do is rent a tank. I have one of these MIGs in my restoration shop and three at my school. They are well worth the price. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 30, 2001 Share Posted December 30, 2001 wanted to say, in my area, I can get a tank for a $50 deposit and just pay for the gas. Check your area. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 30, 2001 Share Posted December 30, 2001 WELDER- THE REASON FOR USING GAS (NORMALLY 75% CO2 AND 25% ARGON) IS A MUCH SUPERIOR WELD. ALSO, THE FLUX FROM GASSLESS WIRE MUST BE WIRE BRUSHED OFF AFTER WELDING. THE FLUX WILL FLAKE OFF AFTER TIME AND NOT WORK GOOD. ALSO, WHEN WELDING SHEET METAL USE ABOUT .024-.025 WIRE. IF YPU GET A 130 AMP WELDER YOU CAN WELD ALUMINUM SHEET METAL. YOU JUST HAVE CHANGE TO 100% ARGON GAS AND USE ALUMINUM WIRE. IF YOU WANT TO WELD THICKER ALUMINUM. YOU MUST AT LEAST 200 AMP WELDER. ALOHA, SUNNY Quote Link to comment Share on other sites More sharing options...
