fcdrifter13 Posted May 25, 2010 Share Posted May 25, 2010 Do they make a Throttle position sensor for a 4150 holley carb with a manual choke. I am starting to think I might be a little slow and cannot find it. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted May 25, 2010 Administrators Share Posted May 25, 2010 TPS for a mechanical secondary 4bbl carb?... Using the cool Google search for "Holley TPS" revealed these two links; http://www.holley.com/HolleyNews/article.asp?ID=196 and; https://holley.com/data/Products/Technical/199R10499.pdf Is that what you are looking for? Quote Link to comment Share on other sites More sharing options...
fcdrifter13 Posted May 25, 2010 Author Share Posted May 25, 2010 No not necessarily, my 4150 has a manual chock and I am not sure if the kit for an electric choke will work. Tried google and bing with the same results and tried searching around holleys website as-well with no strait forward answer. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted May 25, 2010 Administrators Share Posted May 25, 2010 Hmmm... Looks like it attaches to the auto-choke body itself. Interesting they are not offering or mentioning a manual choke option?!... Marketing probably felt that most consumers wanting a TPS are probably auto-choke users. Some possible options; 1) Gut out an auto-choke assy and attach your manual choke cable to the actuator arm? 2) Swap over to auto-choke? 3) Build an adaptor bracket that attaches that TPS to the manual choke assy? 4) Contact Holley and ask them about a manual choke version? Quote Link to comment Share on other sites More sharing options...
fcdrifter13 Posted May 26, 2010 Author Share Posted May 26, 2010 I am going to call them in the morning. I know it sounds stupid but I really only need a TPS for data logging instead of what holley sells it for, shifting of ECM controlled transmissions. If there is a better way I am very open to any options, or opinions. Quote Link to comment Share on other sites More sharing options...
